Water Seeping In Bathroom Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-18-2011, 10:26 AM   #1
Water seeping in bathroom floor
On my main floor bathroom water is seeping up through my vinyl tiles. There doesn't seem to be anything leaking from the toilet or sink. I don't know how we would check to see if the tub is leaking? Does anyone have any idea what could be causing this?
geris is offline   Reply With Quote
Old 08-18-2011, 10:57 AM   #2
DIY staff
Rewards Points: 7,174
Have you removed the toilet yet??
That's the most common cause---Ase you on a slab or wood framed floor?
As to the tub--an in wall camera inserted through the mixer valve hole could see under the tub.
Old 08-18-2011, 07:28 PM   #3
We have not removed the toilet could it be leaking underneath?
Old 08-18-2011, 07:29 PM   #4
We are on a wood framed floor
Old 08-18-2011, 07:31 PM   #5
take a fell at the toilet to tank gasket and see if the tank is leaking...use tissue to deteck a leak?
Marbledust is offline   Reply With Quote
Old 08-19-2011, 10:09 AM   #6
We are going to replace the toilet I am guessing it is about 20 yrs old. Wish us luck as this is the first time trying something like this. Thanks for your help
Old 08-20-2011, 07:35 AM   #7
DIY staff
Be prepared for a surprise or two---
Soft or rotting wood----rusted or broken flange--those are two common 'little surprises'--Mike---
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Water seeping in garage from floor level kingslymole General DIY Discussions 0 06-09-2010 06:36 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Bathroom floor wet; water coming _out_ of bath overflow. oceanclub Plumbing 6 01-09-2008 09:47 PM
