Water Sand Filter - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-22-2012, 01:19 PM   #16
Water Treatment
Rewards Points: 816
Is it city water that has this much sand in it?
Akpsdvan is offline   Reply With Quote
Old 08-22-2012, 01:30 PM   #17
Originally Posted by quanchai View Post
Sould i install the sandmaster betwin the water pump and the water tank feeding the home ?
You should NOT install anything in the line between the pump and the pressure tank that can be shut off or plug up. Many pumps are capable of creating very high pressures and there is (or should be) a pressure relief valve installed at the pressure tank. Installing a (for example) filter that can plug up between the pump and the pressure relief valve defeats the safety feature of the pressure relief valve.
The Sandmaster (Brand name) is designed to be installed between the pump and pressure tank because the design prevents clogging or plugging up.
Bob999 is offline   Reply With Quote
Old 08-22-2012, 02:06 PM   #18
Its not a pressure tank its, Its just a normal 1000L water tank
quanchai is offline   Reply With Quote
Old 08-22-2012, 02:11 PM   #19
Water Treatment
Rewards Points: 816
How is the water getting into the storage tank?
Is it from a Well? The City? a Lake?
Hand dug well?
If you have that size of a tank, why not put it on a 1-2 degree grade and use the lowest point as a drain off of the sand from the bottom of the storage tank?
Old 08-22-2012, 02:44 PM   #20
Water is getting to the tank from the city
Old 08-22-2012, 02:46 PM   #21
Its a simple and brilliant idea but i still want to add that filter
Will the water sand filter used for swimming pools work ?
Old 08-22-2012, 03:09 PM   #22
Water Treatment
Rewards Points: 816
Using the storage tank as a settling tank would work the best.
Draining off the sand at the bottom once a year or so and no filters to change or do maintenance on.
Also you need to find out from the City if the water is starting off with that much sand or if there is problem with the city supply line in your area, ie a break and water getting out and dirt and sand getting in as that should be FIXED By the City.
Old 08-22-2012, 03:28 PM   #23
Well i will do the settling tank thing
But my question is if adding the salt water seperator will it work ?
Old 08-22-2012, 03:40 PM   #24
Just an update
Its not just sand its Sand + Clay
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
