Old 11-25-2011, 03:40 PM   #1
Water Running Noises
constant water running noise as if water is running somewhere in the house but have checked all toilets, sinks, outdoor hoses and cannot find leak. *If I turn off the main water shut off valve in the basement which is where the noise is the loudest, the noise stops.
Rozmo is offline   Reply With Quote
The Following User Says Thank You to Rozmo For This Useful Post:
rossfingal (11-25-2011)
Old 11-25-2011, 04:14 PM   #2
If you have a meter, check and see if the dial is moving when everything is "off".
You have something that is leaking if the sound disappears when you shut the main off.
Ron
B. Franklin 1759
Old 11-25-2011, 05:10 PM   #3
Humifier on furnace? Ice maker?
Old 11-25-2011, 06:08 PM   #4
"Nail-Bender"
"If I turn off the main water shut off valve in the basement which is where the noise is the loudest, the noise stops."
Does the noise stop completely?
Have a plumber come out and check it.
Post a picture/s of the valve you're referring to.
Any evidence of water anywhere?
rossfingal
rossfingal is offline   Reply With Quote
Old 11-25-2011, 07:04 PM   #5
jburd964's Avatar
I don't know how you checked toilets are anything else in house, but if you just looked at toilets for overflowing they can also leak out under flapper and it can be deceiving. My suggestion would be to go to each fixture and appliance and turn them off one at a time. If you can't locate source that way you may have to call a plumber. I guess you've checked the yard?
jburd964 is offline   Reply With Quote
Old 11-25-2011, 08:38 PM   #6
sdsester's Avatar
Faulty valves or crack in water lines to washer? Do you have an irrigation system without its own cut-off valve? Might have a fractured diaphragm or something in one of the irrigation valves or the little screw for manually overriding a valve may have come loose just a bit.
sdsester is offline   Reply With Quote
Old 11-25-2011, 08:49 PM   #7
go and shut off each fixture by its own shut off one at a time and listen after each valve is shut down to see if noise stops ....you should find the problem,,,
Old 11-25-2011, 10:54 PM   #8
biggles's Avatar
testing a toilet flapper leak shut the water valve to the tanlk check it in the morning.if it's empty your loosing water should be full if you left it full after the shutoff
Cold water running Amok in Hot pipes genproj Plumbing 2 04-25-2011 07:56 AM
Lost Hot water pressure brile Plumbing 11 11-28-2010 03:59 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
