Water Running Down Waste Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-27-2009, 09:29 PM   #1
water running down waste pipe
I noticed water running down the waste pipe from my upstairs bathroom. Water is running down pipe to basement. If we use the sink in the upper bath, the water does not run down the pipe. Initially it only happened when toilet was flushed, now dripping all the time. If I shut off the water supply, the drip stops. No obvious signs of leaks at valve or under toilet. Any thoughts?
rav927 is offline   Reply With Quote
Old 06-27-2009, 10:26 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Check the flapper valve in the toilet
Old 06-28-2009, 06:46 AM   #3
I assume you mean the water is running down the outside of the pipe, not inside where it belongs. If yes, and there are no signs of leaks from the shutoff or supply tube, I am baffled. Unless there is more than one problem. Water overflowing into the overflow tube and a bad wax seal. Leaking when the toilet is flushed is a definite indicator of a bad wax seal, or a broken flange, or a leaking pipe.
Old 06-28-2009, 08:34 AM   #4
thank you for the replies-yes, the water was running down the outside of the waste pipe. Eventually, it did stop leaking. There is no sign of water anywhere on the tank or floor in bathroom. I replaced the wax ring. I guess it's time for a pro.
Old 06-28-2009, 08:43 AM   #5
All too common problem is a failed or mis-applied wax ring, or rotted closet flange, allowing water to infiltrate the subfloor. The leak will not present itself around the base of the toilet unless the closet flange is sealed to the finished floor, or if the leak flows quickly enough to flow from beneath the toilet. If your leak is flowing down the outside of the drain pipe, it may not be getting into the subfloor - that's good. Regardless, I would pull the toilet, inspect for wetness in and around the closet flange to identify the actual leak path, and repair as appropriate. I had to re-plumb both closet flanges in my house to bring them up to the level of the remodelled finish floor, thus allowing the was seal to remain water tight. What a hassle.
rizzo is offline   Reply With Quote
Old 07-04-2009, 09:24 PM   #6
yank the john
i've found leaks in the drain fittings before........................ if you have enough bathrooms you can isolate the fixture by not using them for a few days each. i didn't think so. none of my customers have went for that yet. breid
breid is offline   Reply With Quote
Hot water faucet pipe thumps then flow slows down. DIY-Indy Plumbing 9 07-15-2009 11:09 PM
Hot water keeps running Ed36 Plumbing 4 05-14-2009 12:39 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
Water well running dry? Proulx06 Plumbing 4 02-28-2008 09:17 PM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
