Water To Refrigerator - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-22-2010, 07:27 PM   #1
water to refrigerator
My refrigerator is across the room from my sink, I also have no foundation so therefore there is a crawl space. I'm hoping not to have to crawl under the house. I need to have a water line hooked up by Friday for my new frig. what route can I take to get this done?
Suegilbert is offline   Reply With Quote
Old 09-22-2010, 09:11 PM   #2
Rewards Points: 1,088
Unless you live in a warm climate, I wouldn't recommend running that water line through your crawlspace.
handy man88 is offline   Reply With Quote
Old 09-22-2010, 09:24 PM   #3
HVAC / Plumbing
where are your other water lines ? If there under the house you may have to tap 1 of those lines & dirll through the floor & bring the water line up. If it gets real cold there just insulate the line
kenmac is offline   Reply With Quote
Old 09-23-2010, 06:21 PM   #4
Hard to insulate the line in a crawl space since warm air rises in the living space.
Old 09-23-2010, 06:27 PM   #5
HVAC / Plumbing
I have insulated many water lines ( in my 25+ years of plumbing) in the crawl space after replacing them from rupturing from the cold . It's not hard at all to insulate them...Just slide insulation over them
Old 09-23-2010, 06:33 PM   #6
I don't doubt that, but if you live in a cold part of the US like Mass or upstate NY or Minn, I wouldn't do it.
Old 09-23-2010, 06:55 PM   #7
HVAC / Plumbing
I don't recall hin saying where his water lines are currently located. Not to many places to put them in a home. Walls, crawl space, attic, concrete slab. If freezing is an issue . I have also used a product such as this
mnfactore states...prevents pipes from freezing down to -40
It doesn't get that cold here but, I've had custoners request I install this type product on their water lines in crawlspace
Old 09-23-2010, 08:46 PM   #8
basement, no problem....crawl space...different story.
Old 09-23-2010, 09:25 PM   #9
HVAC / Plumbing
You might not be able to keep pipes from freezing in a crawl space. But I 've already been there & done that.. Where there's a will there's a way
Old 09-24-2010, 04:47 PM   #10
Where do you live?
Old 09-24-2010, 11:08 PM   #11
Owner
LateralConcepts's Avatar
I live in Idaho. I was born and raised in Idaho. It can at times reach -20 during the winter months. My entire home is plumbed through the crawl space. As is typical in the area. The crawl space is well insulated. Likewise, the vents are opened in the summer time and closed in the winter time. I've never had a problem with freezing. Freezing of pipes is due to neglect, lack of insulation, or exposure to wind.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 09-25-2010, 07:41 AM   #12
Rewards Points: 1,214
Crawlspace or trays? Your choice.
COLDIRON is offline   Reply With Quote
Old 09-25-2010, 11:13 AM   #13
Lack of problems with freezing of water outside the house in cold water climates could also mean inefficient retention of heat in the actual living space.
Old 09-25-2010, 11:19 AM   #14
Owner
Didn't you say hot air rises?
Lateral
(208) 818-8241
Old 09-25-2010, 11:50 PM   #15
It does, so if you're able to keep water pipes above freezing in a crawl space, there's got to be heat escaping there.
Note that as temperature rises, so does pressure. It's called the ideal gas law.
Water line for new refrigerator? pa555 Plumbing 5 06-08-2012 07:06 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
refrigerator water dispenser tackley Plumbing 2 07-05-2009 05:49 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
