Water Pump Turns Off - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-24-2010, 11:51 AM   #1
water pump turns off
I have a well pump that is a Red Jacket brand. The pump turns on for about 10-20 seconds, the sprinklers come up and start to sprinkle, and then it turns off. The breaker that runs the pump is tripped. Any guesses as to what would do this and how to fix it?
Mikieboy is offline   Reply With Quote
Old 07-24-2010, 12:50 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
What kind of pump is it? Do you have a pumptech electronic control box or similar OR a low water cutoff at the pressure tank?
Are you talking about a breaker in the circuit panel, or the electronic control for the pump?
Sounds like you MAY have a leak, but without more info, it's hard to say. . . .
Journeyman Plumber
Old 07-24-2010, 09:34 PM   #3
If it is a capacitor start motor the capacitor could be bad, or if it has a centrifugal switch it could be bad.
hayewe farm is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 12:59 PM
