Old 03-07-2010, 08:26 PM   #1
Electrical Contractor
kbsparky's Avatar
Water pump schreeching
Today, I noticed a loud screeching noise coming from under my house while the water pump was running.
This concerns me that maybe the bearings might be wearing out, and/or leaking.
This is a GOULDS ½ hp jet pump, purchased and installed over 20 years ago.
The only problem I have ever experienced with it was a few years ago, when the centrifugal switch to connect the starting windings broke. A simple repair and less than $10 fixed that.
Think it's time for a new pump at this point?
-KB
kbsparky is online now   Reply With Quote
Old 03-07-2010, 08:33 PM   #2
Super Moderator
Not looking good there Sparky--You know the expensive sounds from the cheap ones---
Sounds like a faithful friend is asking for retirement.---Mike---
oh'mike is online now   Reply With Quote
Old 03-07-2010, 08:37 PM   #3
Licensed Master Plumber
Time to either rebuild it or change it. It's either bearings or the impeller rubbing on the housing
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 03-07-2010, 09:43 PM   #4
kbsparky's Avatar
How does one go about rebuilding this type of pump?
-KB
Old 03-08-2010, 06:09 AM   #5
You can get a rebuild kit from goulds.
Old 03-08-2010, 10:11 AM   #6
Doing it myself
Alan's Avatar
Rebuild it if you have the capability. Paying someone to rebuild it would likely cost nearly as much or more than a new one, unless you have a friend who does it for cheap / free.
Journeyman Plumber
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Well Water, Fluctuating Water Pressure, and the Roller Coaster Pressure Gauge huuuss Plumbing 24 12-11-2011 10:03 PM
water pump problems excb-terry Plumbing 12 10-27-2009 09:43 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Water Stinks with recirculation pump carike Plumbing 6 08-05-2008 09:01 AM
