Water Pump Quit - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-23-2016, 03:35 PM   #1
Rewards Points: 146
Water Pump Quit
I had such great help with my daughter's central air unit, I thought ya'all might be able to help with my well pump just dying...
Well pump died..
I am fairly sure that I am getting power to the pump. There is a Water Softener attached to the electrical and I hear it ticking so I am pretty sure I have power..
There is a box attached to the well pump and that has been a problem in the past...
I cleaned the contacts and, as you can see they are in the CONTACT position... (RED BOXES)
The GREEN are the wires coming in from the ground. The BLUE are the wires that go into the pump..
Is it a good/bad/ARE YOU NUCKING FUTZ!!! idea to directly connect the hot wires coming in to the pump to see if the pump is working??
Any assistance would be greatly appreciated as I really REALLY need a shower... :^/
Michale32086 is offline   Reply With Quote
Old 04-23-2016, 05:39 PM   #2
joed's Avatar
Rewards Points: 12,854
Re: Water Pump Quit
I would start by checking for voltage on the green wires.
Check the breaker supplying the power.
If the cable runs underground there could be a fault in the cable. That does not look like underground cable.
The Following User Says Thank You to joed For This Useful Post:
Michale32086 (04-24-2016)
Old 04-23-2016, 05:48 PM   #3
Rewards Points: 6,652
Re: Water Pump Quit
Those contacts can get burned and not work. It depends on if closed is off or on.
You can try bypassing the relay and see if the pump will run. If it does, go to the local electrical warehouse and pick up a new relay box.
The Following User Says Thank You to gregzoll For This Useful Post:
Old 04-23-2016, 06:00 PM   #4
Rewards Points: 146
Re: Water Pump Quit
OK, the breaker has been ON since I posted the initial post...
I went out to swap over the wires to bypass the relay...
The pump was literally too hot to touch...
That would seem to indicate that my pump is fried....
That sound about right???
The Following User Says Thank You to Michale32086 For This Useful Post:
gregzoll (04-23-2016)
Old 04-23-2016, 08:57 PM   #5
Rewards Points: 1,402
Re: Water Pump Quit
How were you touching the pump? I'm not an expert, but in my experience a residential pump is usually submerged at the bottom of a drilled well...
Tom738 is offline   Reply With Quote
The Following User Says Thank You to Tom738 For This Useful Post:
Old 04-23-2016, 09:10 PM   #6
joed's Avatar
Re: Water Pump Quit
The pump is the issue. I imagine if it was turning you would have heard it. so it must be seized.
It could also be running dry. that would overheat the pump.
Sounds like you need a new pump.
The Following 2 Users Say Thank You to joed For This Useful Post:
gregzoll (04-23-2016), Michale32086 (04-24-2016)
Old 04-23-2016, 11:40 PM   #7
Re: Water Pump Quit
New Pump, new relay. Are they using a tank right now for water, or some other way? How hard is it going to be to pull the pump? Some people have built rigs out of fence piping or Steel Conduit, to help give a way to hook on a couple of pulleys to help bring the pump up.
Old 04-24-2016, 02:18 AM   #8
Rewards Points: 146
Re: Water Pump Quit
The water pump is above ground..
I had left the breaker off all night, hoping magical elves would come and fix my pump..
No such luck...
I'll get some shots of unit when I get home this afternoon...
Old 04-24-2016, 06:43 AM   #9
joed's Avatar
Re: Water Pump Quit
The pump likely has a centrifugal start switch. If that switch is stuck in the run position the pump will never spin and it will heat up.
The first thing to do is to spin the pump by hand and see if it turns.
Old 04-24-2016, 06:52 AM   #10
Rewards Points: 146
Re: Water Pump Quit
Thanx...
I am at work right now.. I should be home around 1600hrs EST, USA and will check that...
Thanx to all for the replies...
Old 04-24-2016, 04:10 PM   #11
Rewards Points: 146
Re: Water Pump Quit
OK Home now..
The pump is kinda a sealed unit. No way to manually turn it...
I pulled the end-cap off thinking that the spindle might stick out..
No such luck..
Old 04-24-2016, 04:28 PM   #12
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Re: Water Pump Quit
Unbolt the pump from the motor.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
Old 04-24-2016, 04:33 PM   #13
Rewards Points: 146
Re: Water Pump Quit
Just occurred to me..
If I loosen the bolts marked in red and try and separate the pump from the front (impeller??) housing, I might be able to A) turn the pump manually and 2) see if anything in the front housing is jamming up the pump...
Idea???
Old 04-24-2016, 04:34 PM   #14
Rewards Points: 146
Re: Water Pump Quit
Originally Posted by rjniles View Post
unbolt the pump from the motor.
esp!!!!! :d
Old 04-24-2016, 04:39 PM   #15
A "Handy Husband"
rjniles's Avatar
Re: Water Pump Quit
If the motor is shot and the pump is good, just replace the motor. A lot less plumbing.
Help with Sump Pump Issue (Drainage as well) neverlandpirate Plumbing 2 12-30-2015 07:57 AM
Sump Pump Running Constantly - Never Ending Water! seldom Plumbing 7 12-08-2015 07:59 AM
Hot Water Recirculating Pump For Mobile Home justplumducky Plumbing 0 08-17-2014 09:15 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Heat Pump Water Heater Review wassermeister Plumbing 0 08-25-2012 03:35 PM
