Water Pump Problems - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-03-2010, 04:58 PM   #1
Water pump problems
I have a deep well pump that seems to be refusing to prime. We live in N. Arizona and there is no underground water, so we have to haul water and dump into an underground cystern. We have had some bad weather and could not get in to add water until yesterday. This morning, after the temps had warmed up, I started trying to get it running. It doesn't build pressure and just hums. Do I need to just keep adding water? I wish I understood how these things worked.
aztxtq is offline   Reply With Quote
Old 01-03-2010, 05:19 PM   #2
An old Tradesmen
Rewards Points: 8,184
Moved to Plumbing forum.
Old 01-03-2010, 05:28 PM   #3
Licensed Master Plumber
Is it a submersible pump (in the well) or a jet pump?
NHMaster is offline   Reply With Quote
Old 01-03-2010, 05:54 PM   #4
Rewards Points: 150
LOL You must be tried. Think about......Why would he prime a submersible?
user69544 is offline   Reply With Quote
Old 01-03-2010, 06:25 PM   #5
I only asked because he said it was a deep well pump. It probably is a 2 line set with the jet down the well in which case he's probably having problems because the jet is plugged but It never hurts to get clarity.
Old 01-03-2010, 06:30 PM   #6
Rewards Points: 150
I know....just ribbing ya.
Old 01-04-2010, 01:39 PM   #7
Lightbulb
Deep Well pump is usually the term used for a 2 pipe system to the well on your case a cystern. If the pump only hums it sounds like you either have a frozen pump or a motor electrical problem.
Try unplugging the pump, remove the cover from the back of the motor and hopefully you can turn the motor shaft by hand or with a screw driver. If you can't turn the shaft easily, the pump is probably froze. If you can turn it, you have a motor problem.
If the pump is frozen, thaw it out with a heat lamp and hopefully it will be OK.
When you get the pump to run and not just not humming it should prime and you should have water.
Porky Cutter, MGWC
(Master Ground Water Certified)
www.dci-inc.us
Porky is offline   Reply With Quote
Old 01-04-2010, 02:44 PM   #8
Can a I mess up the pump with a new tub?
Like any good DIY'er I made sure to turn off the water supply before I began plumbing work. I found this company with walk in tubs Atlanta suggested as a number one company. I got one and it went in like a glove and the water is on. I think my pump is gone. What could I have done during installation
PT2009 is offline   Reply With Quote
Old 01-04-2010, 03:05 PM   #9
Cutting off the water and installing a new tub shouldn't have anything to do with the pump. Do you have water pressure and power at the pump?
Old 01-05-2010, 06:02 PM   #10
Day four and finally time to mess with pump. It is a jet pump and sounds like a hum as Porky said. The temps have warmed up considerably today so going back out to take the back off the pump. Wish me luck! and thanks for input.
Old 01-05-2010, 06:33 PM   #11
By the back off the pump I mean the back cover off the motor.
Good luck and keep us posted
Porky, MGWC
www.dci-inc.us
Old 01-05-2010, 07:36 PM   #12
Well, I'm back. It's not a deep well pump. It says it's a Craftsman shallow well pump. The back is all one piece. That is where the hum comes from. The front that leads out into the water pipes and the big disk shaped thing don't seem to be emitting any sound. Is it possible the drive shaft or whatever the motor turns somehow got disconnected from something and is spinning free and not turning? Sorry, newbie doesn't even begin to describe me!
Old 01-05-2010, 09:08 PM   #13
Rewards Points: 150
I would just replace it. They are not that expensive. Make sure you get the same kind to bolt up to the well.
Old 01-07-2010, 11:07 AM   #14
Rewards Points: 150
i did and am very happy
rudolph58 is offline   Reply With Quote
Old 01-07-2010, 11:13 AM   #15
Rewards Points: 150
how deep is the cistern.a submersible is self priming as long as water is above the top of the pump.a lot less maintenance and problems.
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
dug (bored) water well problems jurban Plumbing 2 10-01-2009 05:45 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
