| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How to Do a Maintenance Check on the Radiator of a Polaris ATV
by Expert Village
On behalf of Expert Village my name is Tom Roland and we're at Cottonwood Motor Sports and I'm here to tell you about doing service on a Polaris Quad and this is fairly representative of many of them. The radiator on a Polaris on the units with a box on... Read More »
The Parts of an Air Compressor
by Expert Village
Hi this Jon on behalf of Expert Village in this video clip I'll be showing you the parts of an air compressor. First off is the tank pressure gage that's located right here it goes directly into the tank. This is going to tell you the actual pressure... Read More »
How to Make a Solar Pump
by eHow.com
When you need to pump water to a distant field, sometimes it's not convenient to run the pump with electricity. In such an application, a solar pump works well. Fortunately, you can do this yourself. This eHow can help you get started. Read More »
Checking Gasket to Change Fuel Pump
by Expert Village
Hi my name is Jeff Fiffie. I'm showing you how to move and replace a fuel pump on a Lincoln Continental. The first thing you want to check is your oil ring, checking it very closely to make sure there's no dry rotted. There's more cases when you receive... Read More »
Identifying Problem With a Toilet
by Expert Village
Now, to check to see if this toilet has a leak in it, what you can do is you can take, and put a little bit of food coloring into the tank. If there is a leak in this toilet, the water food coloring will go through the tank, and end up in the bowl. So... Read More »
