Water Pressure In Shower Issues - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-06-2009, 12:34 PM   #1
water pressure in shower issues
A few months ago the pressure in my shower was just fine, then one day i turned the water on and it made a funny noise and the pressure was horrible. I messed with the knob a little and after about 1 day it fixed itself and everything was good. I figured something was clogged somewhere. Then it happened again the a few days ago. I got the water pressure a little bit better but its still not where it was or should be. Any ideas on whats going on? The pressure in the sink is normal, its only in the shower. thanks!
sflamedic is offline   Reply With Quote
Old 04-06-2009, 01:38 PM   #2
Man of many hats
wrangler's Avatar
Rewards Points: 354
Sounds like it could possibly be debris in the shower head or the valve itself. I would start with removing the head and checking to see if the strainer is clogged or if something is rattling around in the head. I had one that the HO had tried 'pushing' the water saver through into the head, and every now and again it would foul the water flow. While you have the head off, run a few gallons through the neck with no head as well. If no there, it must be a problem with the valve/cartridge.
Man of many hats
wrangler is offline   Reply With Quote
Old 04-06-2009, 03:39 PM   #3
how do you remove the cartridge? I took the handle off and removed a u shaped piece of metal but the cartridge is not budging. Thanks for the help.
Old 04-06-2009, 10:09 PM   #4
OKay i changed out the valve and cleaned the shower head with clr and water. Still the same flow. Not horrible just not what it was a week ago. any ideas?
Old 04-06-2009, 10:41 PM   #5
HVAC / Plumbing
must be in the control or the water line it's self... What type water lines ??
kenmac is offline   Reply With Quote
Old 04-07-2009, 05:58 AM   #6
Man of many hats
wrangler's Avatar
Rewards Points: 354
How was the water flow when the showerhead was off? Was it equally strong when fully hot and fully cold?
Man of many hats
Old 04-07-2009, 01:28 PM   #7
Rewards Points: 150
might try buying a cheap shower head and put on and see what happens. call your plumber he might have one laying around that he would love to get rid of.
al's sewer is offline   Reply With Quote
Old 04-07-2009, 02:45 PM   #8
Its only a shower so i cant check to see the water flow without the shower on. I was thinking about buying a new head also. The lines are copper i believe.
Old 04-07-2009, 02:55 PM   #9
Man of many hats
wrangler's Avatar
Rewards Points: 354
What I asked was, when you had the shower head off to clean the screen and check for debris, did you run the water to flush the pipe, and if so, did the pressure seem particularly low? If so, then def a prob with the shower head.
Man of many hats
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
hot water check valve? Ultrarunner2017 Plumbing 7 01-30-2009 02:36 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
New install shower has poor hot water pressure rwhitne Plumbing 2 01-20-2008 05:13 PM
water heater issues Missydo Plumbing 17 04-05-2005 10:31 PM
