Water Pressure Regulator Valve Installation - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-26-2010, 03:48 PM   #1
water pressure regulator valve installation
Can I install a pressure regulator valve in a copper pipe with flared fittings instead of sweating in fittings?
greg Cool is offline   Reply With Quote
Old 11-26-2010, 04:23 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
As long is the copper is soft copper tubing. You can not flare hard copper.
Coastal South Carolina
Old 11-26-2010, 06:32 PM   #3
Rewards Points: 150
You can also use compression fittings.
braindead is offline   Reply With Quote
Old 11-26-2010, 06:50 PM   #4
Rewards Points: 468
Is this to turn pump motor on and off when preasure get's to what ever preasure switch is ?? If so put it where it is sopose to go?
del schisler is offline   Reply With Quote
Old 11-26-2010, 06:57 PM   #5
A "Handy Husband"
rjniles's Avatar
What does this mean? OP said a pressure regulator, not a pump pressure switch.
Old 11-26-2010, 07:00 PM   #6
Rewards Points: 468
i guess i had a preasure switch on the brain.
Questions about water pressure regulation.. MrSimmonsSr Plumbing 20 11-30-2012 10:43 PM
Hot water pressure problem glamgirrl Plumbing 6 09-21-2010 11:43 AM
what is the thing called that stores water under pressure for low water pressure? oregongirl23 Plumbing 18 08-08-2010 03:09 PM
Low/No Hot Water Pressure after changing Elements Onehipcat Plumbing 18 08-05-2010 10:16 AM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
