Water Pressure Regulator Behind Drywall - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-12-2010, 06:49 AM   #1
Rewards Points: 20
Water Pressure regulator behind drywall
New home and the JackHole contactors installed the pressure regulator somewhere behind the drywall. Is there any kind of x-ray equipment or the likes that can find it behind the drywall?
diynoobee is offline   Reply With Quote
Old 08-12-2010, 08:39 AM   #2
Is the house new, or "new to you" ? If it is a new structure, contact the builder or the Plumbing Contractor. If this was done years ago, the problems begin. Not sure how you would know a Pressure Reducing valve exists if it is an older home.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
what is the thing called that stores water under pressure for low water pressure? oregongirl23 Plumbing 26 05-31-2017 09:50 AM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Low/No Hot Water Pressure after changing Elements Onehipcat Plumbing 18 08-05-2010 09:16 AM
Decreased Water Pressure in home Gordon07 Plumbing 4 12-03-2009 11:05 AM
Water pressure dropping tucsoncop Plumbing 2 04-25-2009 12:19 PM
