Water Pressure Regulator - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-10-2012, 08:34 PM   #1
I am needing to replace my house water pressure regulator. I am looking at using:
http://www.homedepot.com/webapp/wcs/...43&R=202721943
1. I don't think that the shark bite will work with schedule 40 PVC is that correct?
2. Is the best place for a pressure regulator directly after the water meter or under the house?
3. Any other recommendations for a better regulator - I know that I do not want:
http://www.lowes.com/ProductDisplay?...llow&cId=PDIO1
Thanks for any help or suggestions!!
grgparker is offline   Reply With Quote
Old 05-10-2012, 10:36 PM   #2
No it will not work with PVC, but it will work with CPVC. You shouldn't have PVC at all as water lines as they are not rated to carry potable water.
The best place for a pressure reducing valve is as soon as the water line enters the house.
I have no other recommendations as the one Watts one you show from Lowe's is the one that I use regularly. May I ask why you do not want to use this particular type?
VIPlumber is offline   Reply With Quote
Old 05-11-2012, 12:21 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
It's typical here to install the pressure regulator next to the house shutoff valve outside, and use it as part of the transition from the service piping to the building supply. In that case, it probably has schedule 40 pvc on one end and a ball valve with possibly a brass nipple between the two.
When i started out we were using the 25-aub and got away from that because of the tops rotting out and blowing apart in less than a year.
Now we are using the watt's n55b.
Seem to be having much better luck with those.
Journeyman Plumber
low water pressure from well pump supply dolfan13jmb Plumbing 4 03-03-2011 02:28 PM
Installing Sprinklers appear to have caused Water Pressure to DRASTICALLY increase geminigirl Plumbing 3 11-12-2009 01:04 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
Water pressure dropping tucsoncop Plumbing 2 04-25-2009 01:19 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
