Water Pressure Regularly Goes Down - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-08-2010, 12:05 AM   #1
hohadcr's Avatar
Rewards Points: 306
water pressure regularly goes down
our renter complains that, when he takes a shower, usually 20min long, the water pressure goes down every 5 mins, down to almost nothing, and then comes back again, and drops again in 5 mins. This happens everytime he takes a shower.
What could be the problem? Within the apt, all the pipes have been changed into flex. The city line is still old galvenize.
This city water.
thx
hohadcr is offline   Reply With Quote
Old 05-08-2010, 01:34 AM   #2
Water Treatment
Rewards Points: 818
thx
This is city water?
If this was a well I would say that the air pressure in the pressure tank is not right.
If the switch is a 40/60 then there needs to be 38psi of air in the pressure tank, that is checked when there is NO water in the pressure tank.
Akpsdvan is online now   Reply With Quote
Old 05-08-2010, 08:06 AM   #3
hohadcr's Avatar
Rewards Points: 306
well, it is city water...
Old 05-08-2010, 08:28 AM   #4
Rewards Points: 1,418
If he ran the water in the washbasin does he have the same problem?
There could be a problem in the shower faucet, particularly if there is an anti-scald feature.
Old 05-08-2010, 11:50 AM   #5
Could be the showerhead or a loose faucet washer.
Measure the flow rate before and during the fault with a bucket and wrist watch.
Then remove the shower head and try again, duplicating the same flow rate without the head on. Then try it at full flow.
I'd expect different flow rates would change the five minute period to something longer or shorter or it may clear the problem entirely.
Is the change abrupt or gradual?
Since this fault can be reliably reproduced there is a good chance you can find the problem.
There are analogies between plumbing and electrical circuits, and the electrical circuit analogy for this is a very low frequency oscillator.
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 11:24 AM
Low water pressure upstairs but gauge reads 100psi? rivers72 Plumbing 7 11-15-2008 08:55 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
New Help With Improving Water Pressure hayhursm Plumbing 1 01-31-2006 07:55 PM
