#1 |
water pressure and reducing diameter
i have installed a fountain submersible pump in my pond to use to water my garden / flowers. The discharge is 1 1/4 ". I want to reduce it to 1/2 " to connect to a water hose. Does it make any difference to
resulting water pressure if i reduce in one stage or in several stages ? |
#2 |
By doing it that way it may over heat the motor depending on the pump design.
#3 |
Well, from a fluid mechanics point of view, one reduction is better at least in smaller diameter piping, like going from 1 1/4 to 1/2". But pressure might suffer to where you notice it when you turn the water on if you are reducing to 1/2" at the pump and you have a distance of over say 20 or so feet to travel to the hose bib.
Now it seems like to me when I used to put in a tap for whatever, that it was so convenient I used it for a whole lot more stuff than my original intent. The first couple of times I just used the size necessary to do the job but after that I started going one size larger on pressured water piping. I mean you never know right? |
| Tags |
pipe diameter, water pressure ![]() |
| Display Modes | |
| rumbling pipes and leaking pressure relief valve | rogerwright | Plumbing | 21 | 04-14-2012 03:35 PM |
| Need Advice on how to Correct Low Water Pressure | Joe Tilghman | Plumbing | 51 | 04-13-2012 01:11 PM |
| Reducing water pressure of the heating system | Effar | HVAC | 20 | 12-28-2011 09:09 AM |
| Intermittent Low Water Pressure | Fox | Plumbing | 4 | 03-02-2010 07:04 AM |
| Filling a Cast Iron radiator system | insulatorpro | HVAC | 7 | 10-07-2008 12:31 AM |
