Water Pressure Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-10-2007, 09:40 PM   #1
water pressure problem
Hi my sister has been having a problem with water pressure to her shower on the 2nd floor, she is on a well and has problems with hard water, the strange thing is that it only seems to be a problem with that shower and its intermittent, the shower will start off good then go to a trickle and then it will be ok and so on. any ideas? I replaced her pressure switch but that didnt do it. thanx Kevin
krw1957 is offline   Reply With Quote
Old 12-10-2007, 11:34 PM   #2
Master Plumber
Rewards Points: 150
Always start by removing the shower head and working backward from there to look for pressure problems, the well is at the beginning of the system, start from the end...the shower head, remove it and see if the pressure is good, shower heads easily clog with debris due to all the flow restriction of water saving devices. I am assuming what you say is correct about the problem only being at the shower.
jpplumber is offline   Reply With Quote
water pressure problem rgmetro Plumbing 6 04-09-2007 04:57 PM
High pressure in water line atlfiveo Plumbing 5 02-06-2007 10:04 PM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
Water Delivery Problem amadis Appliances 6 12-20-2006 11:22 PM
New Help With Improving Water Pressure hayhursm Plumbing 1 01-31-2006 07:55 PM
