water pressure no staying after pump shuts off
Your expansion tank or pressure tank may be saturated. If the air pocket in the tank is too small, then the pump will sense a sudden pressure rise and then shut off. Then any slop in the back flow preventer causes the pressure to drop back a bit. If the pressure does not fall back too far then the pump won't come back on immediately and repeat the off and on, pressure rise and drop regimen over and over.
If you turn off the pump, empty all the water out of the pressure tank, expand the bladder all the way down to the water inlet end (maximizing the air pocket), let out the excess air under pressure, and then put everything back together and turn the pump back on, you will usually get the system back in order with only small pressure changes close to the correct pressure (or only occasional small deviations outside the high and low pressure limits you set). Your pump or pressure tank may have more precise instructions for setting the correct pressure.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
