Water Pressure With Multiple Showerheads - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-09-2008, 07:38 PM   #1
water pressure with multiple showerheads
ok, we have a 5x5 shower that has one shower head. we are about to rip all the old tile out and put up new durarock and tile. in the process we were wanting to add a second shower head directly across from the first and also add a hand shower on the back wall. what do i need to do to ensure proper water pressure when i tee the other two lines off the main one?
robbie2883 is offline   Reply With Quote
Old 09-09-2008, 07:49 PM   #2
Hopefully, you can come off of a 3/4" main line for the two 1/2" tees for showerheads. If you try to run two showers with one 1/2" line, you will greatly lack pressure. The handheld could be taken off one of the shower supply lines since it probably won't be used at the same time as the showerheads. On new construction of this type, we run a 1" main for multiple showerheads. Hope you have a large water heater also.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 09-09-2008, 07:56 PM   #3
Registered User
Termite's Avatar
I tapped my 2nd head into a 3/4" PEX line with 1/2" PEX to the valve, and it works great. Definately not lacking pressure or volume.
Don't forget to waterproof that backerboard before you tile!
Questions about water pressure regulation.. MrSimmonsSr Plumbing 21 05-13-2017 07:08 PM
Water pressure and temperature billvasko Plumbing 9 06-02-2008 09:23 AM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 10:29 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 11:19 AM
New Help With Improving Water Pressure hayhursm Plumbing 1 01-31-2006 06:55 PM
