Water Pressure Lower And - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-13-2012, 10:13 PM   #1
Question
water pressure lower and
Hi, I have a weird one for you. I've tried googling this, searching other forums, and searching this forum so I figured I did my due dilligence searching on my own, but no luck.
My water heater (40 Gallon Gas Kenmore) was leaking so we called a plumber out. It started with a slow steady stream off the pressure relief valves down spout, then a faster (but not crazy fast) stream for an hour or so after showering or using hot water. The plumber said that just the relief valve was bad and replaced it.
Later, I went to give my 11 month old daughter a bath, I noticed that I had to turn the water to a hotter position on the dial, a lot more than normal, and the water pressure was lower. I figured I "may have" had the heater turned up a little higher than I should have before the valve went bad, and the plumber had set it to what it is really supposed to be set at. When I turned the bath off (one dial faucet, left for hot, right for cold, all the way right is off) there was a steady stream of water running and it ran for about 20 minutes.
Even later, when I took a shower, it did it again.
Could the plumber have turned down our water pressure? Put a wrong rated (?) valve in? I don't know. All of the forums I've read says its the valve behind the shower control (on hot cold) valve, but it would be an odd coincidence if that went bad tonight!
Any help is appreciated..Sorry for the long post!
boomjack is offline   Reply With Quote
Old 02-13-2012, 10:52 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Im not sure what the pop off valve could have done to cause this,my guess would be when he shut off the water to replace the pop off valve some crud got knocked loose in the line when he turned the water back on and it worked its way up to your shower valve
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
boomjack (02-13-2012)
Old 02-13-2012, 11:15 PM   #3
that was a fast reply!
Thank you for replying so fast. My other searches said it was the shower valve, but it didn't make sense to me. When you said something may have gotten loose when he shut the water off and replaced the valve, it kind of clicked. The old blow off valve was pretty corroded, so now it makes sense to me. Thank you!
I will be now searching the threads to see how to replace that valve. I pulled the handle off and see the lines going into the valve. My only concern is that its going to leak after I replace it hahaa! Oh well, only one way to find out!
Old 02-13-2012, 11:50 PM   #4
Rewards Points: 14,300
It should not need replacing. The stem just needs to come out and be cleaned as well as the anti scald valve.
Every company is differant on how the valves come apart so unless we know the brand of have a picture it's hard to help.
The water has to be shut off before you do anything.
plummen (02-14-2012)
Old 02-14-2012, 11:48 PM   #5
Very cool, since its Valentine Days I didn't have time to mess with it, but thanks for saving me some money! I looked online and it did not look too difficult, i'm going to dig in to it tomorrow, and hopefully won't have to post a pic (unless i get stuck hahah).
The Following User Says Thank You to boomjack For This Useful Post:
ben's plumbing (02-15-2012)
Hot water pressure problem (unusual situation) tanna Plumbing 2 09-03-2011 08:17 AM
Hot Water Tank and Pressure Help tbakbradley Plumbing 2 01-17-2011 09:25 AM
Intermittent Low Water Pressure Fox Plumbing 4 03-02-2010 06:04 AM
hot water pressure much lower than cold water pressure lockingpin Plumbing 5 12-26-2009 04:23 PM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 03:01 PM
