Old 04-23-2005, 01:22 PM   #1
Water pressure low
water pressure at taps low on unvented system using maxi boiler
angus is offline   Reply With Quote
Old 04-23-2005, 01:39 PM   #2
Water pressure low
This is a mains feed unvented cylinder?
Is there a reduction in pressure on both hot and cold?
The first thing to check is all upstream valves are open and the mesh strainer in the pressure-reducing valve is clean.
dirkgently is offline   Reply With Quote
