Old 11-11-2008, 02:18 AM   #1
Default Water pressure issues - in one part of the house
Hi guys. Here's a quick diagram of our house to illustrate my point. Obviously it's simplified, but here it is:
We get pretty good water pressure in the kitchen, and it's great in the spare bath. However, it's pretty awful in the master bath. I just ran a bath in the master bath, and it's noticeably weaker than it was when we moved in 2.5 years ago. The master bath shower is just dismal - it's like a small insect is spitting on you, whereas in the spare bathroom it feels like a fire hose. It has been a gradual thing - it didn't happen overnight. I assure you that we aren't just imagining things. Also, I can swear that sometimes the water in the master bath doesn't get as hot as it does in the rest of the house, but that's another story.
We just got a new water heater a few months ago, so that shouldn't be the problem. Our house is only about 8 years old, so I wouldn't think it would be a bad pipe issue (or would it?). Also, our water bill hasn't gone up since we moved in (it averages about $25/month), so I don't think we have a leak. I spoke with our local water department in 2007 when we first really started noticing it, and they said that if the water on/off switch in the front yard is fully open (which it is), then there's really nothing they can do. Are there any other potential problems that could cause a loss of water pressure in only one part of the house?
We do have a pretty good home warranty that covers some plumbing issues, but I'm not sure they'd cover something this vague. Thanks in advance for any advice!
stream41 is offline   Reply With Quote
Old 11-11-2008, 02:27 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Remove your shower head and try the water pressure without it. If the pressure seems as strong as at the open tub spout, soak the shower head in vinegar overnight to dissolve the minerals that are clogging it. rinse it out good and re-install it. Use new teflon tape on the shower arm threads by wrapping 2-3 flat wraps clockwise only on them before tightening on the shower head.
If you've lost water pressure in your bathroom sink, remove the aerator and clean out any debris in it.
If that doesn't do it, you may have to dismantle the faucets with the water OFF, place a towel over the dismantled sink faucet, turn it on briefly to flush out any debris in it, and then re-assemble.
The distance between a water heater and a fixture has a lot to do with how long it takes for the hot water to get there, but it shouldn't have anything to do with the pressure.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 11-11-2008, 03:00 AM   #3
Good Luck!
Mike
Thanks for the response Mike.
The weird thing is that the bathtub pressure has diminished as well, so I'm pretty confident that it's not just the shower head. All three water sources in the bathroom - shower, bath, sinks - have diminished in pressure, seemingly at the same rate. I'm not sure why I mentioned the hot water heater - I know it doesn't affect the water pressure.
I will fool with the shower head to see if I can improve things.
Old 11-11-2008, 04:02 AM   #4
Hahaha, I feel like an idiot. Took the shower head off, and the mesh thing was clogged to high heaven. Took it out quickly just to test, and the pressure was great.
Do I soak this in vinegar or what?
Old 11-11-2008, 09:43 PM   #5
biggles's Avatar
quick fix their...remove all the air aters and heads do all the sinks and showers flush them with cold then especially that hot...since that HWH change out.
More On This Topic
In this segment we're going to start with the front door and clean this area. You always want to work from the doorway away. You want to brush all, just like you want to sweep your dust out and away from the house. We also have to be careful right here... Read More »
The Japanese bath house is commonly referred to as the sento. The sento means cleanliness, togetherness and nakedness. The sento is a daily tradition in Japanese culture and doesn't have the aura of taboo that many Americans might expect. A Japanese... Read More »
Opossums are generally clean animals that have little or no odor and do not require periodic bathing. Like cats, they are constantly grooming themselves and keeping their fur free of dirt and debris. If you find it necessary, however, to give your pet... Read More »
Hi! My name is Nate McCullough on behalf of expertvillage.com. In this clip we are going to talk about the proper way to install your brake caliper. Once you have the pads and everything mounted, the brake caliper is pretty straight forward. You want to... Read More »
Hello, my name is Grady Johnson and I'm a professional painter and today I represent expertvillage.com. Okay, now we're going to talk about protecting our plant life. We've got some nice Azeala's here, we've got a pretty big tree over here and we want to... Read More »
Whole House Water Treatment Systems HWPipes Plumbing 15 10-11-2008 08:42 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 01:31 AM
WHOLE house water treatment? What is best for family? stbear007 Plumbing 1 09-07-2008 11:07 AM
House Water Pressure flyultralite Plumbing 7 01-03-2008 07:57 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 12:31 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
