Water Pressure Issues After Repairing Main Water Line. - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-26-2011, 10:31 AM   #1
Water Pressure issues after repairing main water line.
I repaired a leak in the main water line about 6 feet from the meter on Saturday. It is no longer leaking, but I have having issues with my water pressure. The pressure increases and decreases randomly. It will be very little pressure for a few seconds, then increase to normal flow for a few, then decrease again. Seems to be common throughout the house. This has been going on for a few days.
Any ideas? I had to turn the water on and off about 4 different times at the meter as I was trying to find the leak and check that it was stopped. When the water pressure goes down, removing the faucet's aerator does NOT seem to help. Any advice would be great. Thanks!
Cleve99 is offline   Reply With Quote
Old 01-26-2011, 11:06 AM   #2
Jackofall1's Avatar
Sounds like, when you isolated the main by closing a valve you dislodged a gasket or seal and it is now in the pipe, caught in a valve seat or meter.
Old 01-26-2011, 07:13 PM   #3
Picky Plumber
May be some trash in your strainer on your pressure reducing valve if you have one. Is the pressure fluctuation happening on both hot and cold lines? And for future reference, when you repair a leak in the yard or anywhere else that may lead to debris getting into pipe, always turn the tub valve on first before anything else until water runs clear.
Plumber26 is offline   Reply With Quote
Well Water, Fluctuating Water Pressure, and the Roller Coaster Pressure Gauge huuuss Plumbing 24 12-11-2011 09:03 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Intermittent Low Water Pressure Fox Plumbing 4 03-02-2010 06:04 AM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 03:01 PM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 10:29 PM
