Water Pressure Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-23-2011, 10:22 PM   #1
Rewards Points: 27
I have a weird issue with the water pressure in my townhome. On the first floor the kitchen sink has super low pressure for the cold water but the hot water comes out like normal. And on the second floor in the restrooms the cold water comes out normal and the hot water has super low pressure. What could be the cause of this?
woodenSpoon is offline   Reply With Quote
Old 08-23-2011, 10:51 PM   #2
DIY staff
Rewards Points: 7,174
Bad shut off valves
bad faucets
Has it always been like that? Is the tub pressure also low or just faucets?
Old 08-24-2011, 09:38 AM   #3
Rewards Points: 27
The tubs seem ok. I will have to check those later because the tub faucet is the kind with one knob.
Its been doing it ever since I moved in a couple of months ago
Old 08-24-2011, 10:36 AM   #4
DIY staff
Remove the water lines to the faucets and reverse them--if they are long enough.
That will tell you if it's the faucet or the water line/shutoff.
Need help with water pressure issue. Nice_guy Plumbing 4 07-17-2011 09:15 AM
no hot water pressure in sink, but plenty in tub Turtle learner Plumbing 5 10-20-2010 07:45 PM
Intermittent Low Water Pressure Fox Plumbing 4 03-02-2010 06:04 AM
Installing Sprinklers appear to have caused Water Pressure to DRASTICALLY increase geminigirl Plumbing 3 11-12-2009 12:04 PM
Low Hot Water Pressure jifisher Plumbing 10 07-27-2009 06:48 AM
