Water Pressure In House - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-22-2011, 02:25 PM   #1
Landlord
Rewards Points: 89
Water pressure in house
OK, I'm stuck. I was told the water pressure in my rental may be too high. I went out and bought a water pressure gauge, hooked it up to the outside bib and it came up 120psi. I looked closer and the piping to the outside bib is before the pressure reducing valve. How can I measure my water pressure is the question? And to turn down the pressure do I turn the bolt counter clockwise or clockwise. Thanks
cocean is offline   Reply With Quote
Old 06-22-2011, 02:48 PM   #2
Rewards Points: 27
Post
Water Pressure
You'll need to find and tap into another port AFTER the pressure reducing valve. Look for other hose bibs and/or utility faucets that may have a way to connect a gauge.
Most pressure regulators can be adjusted by turning the adjusting screw counter-clockwise to REDUCE pressure and clockwise to INCREASE pressure. If equipped, be sure to lock down the adjusting bolt lock nut after adjustment. Make only small adjustments to the regulator and re-test each time (1/2 turn).
OldSingy is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Big water leak under house Puzzles Plumbing 4 04-27-2011 02:50 PM
House water pressure issue Jim Schueler Plumbing 3 02-23-2011 11:23 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-06-2008 11:31 PM
