Water Pressure Drop Using Two Fixtures - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-21-2011, 06:53 PM   #1
Water pressure drop using two fixtures
Just built a brand new house. The problem I dont understand is that we are experiencing reduced water pressure when we operate two fixtures simultaneously. For instance, turn on sink, hot or cold water then flush toilet and flow from faucet is cut in half. When toilet is full and shuts off faucet flow is restored to normal. Same thing happens with toilet and shower or sink and dishwasher. Happens with any combination of water too, such as cold and cold or hot and cold. We do have a tankless water heater and a well. Although at our other house we had a well and a conventional hot water heater and did not have this problem. Could the tankless heater be the issue or is it something else?
Mpr193 is offline   Reply With Quote
Old 11-21-2011, 07:21 PM   #2
Rewards Points: 340
cold doesn't flow through the water heater, so if the pressure drop is the same regardless of the combination, it's not the water heater. i would imagine it has something to do with the well or how the water is pumped from the well and possibly can't keep the water pressure up at a certain flow rate.
NitroNate is offline   Reply With Quote
Old 11-21-2011, 07:28 PM   #3
Rewards Points: 582
sounds like something going on with pressure switch or well pump make sure pump is starting when pressure guage hit cut in pressure....
Hot water pressure problem (unusual situation) tanna Plumbing 2 09-03-2011 08:17 AM
no hot water pressure in sink, but plenty in tub Turtle learner Plumbing 5 10-20-2010 07:45 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 11:19 AM
