Water Pressure Drop In Tub Only - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-01-2012, 09:24 PM   #1
Water pressure drop in tub only
We have about a 15-20 year old shower with a single handle Delta faucet. The pressure recently dropped by about 50% in both the tub faucet and shower head. The rest of the house still works perfectly, including the sink that's right next to this tub. Any idea what could be causing this?
jettlash84 is offline   Reply With Quote
Old 07-01-2012, 09:31 PM   #2
Rewards Points: 13,300
Time to rebuild or replace it.
If you were to contact the company with a pictue most often they will send you all the parts for free, worth a try.
Old 07-02-2012, 07:32 PM   #3
Any other thoughts on specifically what I can do to fix this without ripping out the tiles or drywall on the other side of the wall? I have no experience with this, but don't want to hire a plumber if it's something somewhat easy.
Let me know if anyone has any thoughts, thanks in advance!
Old 07-02-2012, 07:38 PM   #4
DIY staff
Rewards Points: 7,174
Deltas are easy to repair--the valve body is good for a life time---
Post a picture and some body will recognize it and tell you how to change the guts---
Old 07-02-2012, 07:41 PM   #5
Lightfoot's Avatar
Rewards Points: 272
I can't speak for Joecaption, but i believe he was talking about rebuilding the Delta faucet. No ripping of tiles necessary, just shut the water off and take the faucet apart. Put new parts in, turn water back on. Done. Whatever type Delta you have, just google it, and you likely find instructions for a redo.
Lightfoot is offline   Reply With Quote
The Following 2 Users Say Thank You to Lightfoot For This Useful Post:
ben's plumbing (07-05-2012), oh'mike (07-02-2012)
Old 07-02-2012, 08:32 PM   #6
Lightfoots right.
May need to go buy a special tool to get the whole thing apart.
It looks like a deep well hollow socket with a tee handle on it.
Old 07-03-2012, 12:02 AM   #7
Could it really be something as easy as a partially plugged valve cartridge?
VIPlumber is offline   Reply With Quote
Old 07-03-2012, 05:29 AM   #8
Thumbs up
michel zaki
please clean the tap filter
if nothing changed u have to install larger pipe diameter 25 mm
michel zaki is offline   Reply With Quote
Old 07-05-2012, 09:51 PM   #9
UPDATE
I took all of your advice and took the faucet apart. I went to Home Depot and found the correct catridge replacement. Before I reinstalled it, I turned the water back on and let the water pour out to clean the valves. The water came out so fast it almost knocked me over, so we're getting good pressure.
I put everything back together and the pressure is still low! Any other thoughts, this is driving me nuts
Old 07-05-2012, 10:20 PM   #10
DIY staff
Is the shower head plugged up?
Remove the shower head from the shower arm and test it
Old 07-05-2012, 10:23 PM   #11
The shower head and tub faucet were both reduced about 50% at the same time, so I don't think it's the head.
The Following User Says Thank You to jettlash84 For This Useful Post:
oh'mike (07-05-2012)
What is the standard method of water pressure test for shower plumbing please? Andy21 Plumbing 10 10-28-2011 05:06 AM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
New Help With Improving Water Pressure hayhursm Plumbing 1 01-31-2006 07:55 PM
