Water pressure drop in tub only
We have about a 15-20 year old shower with a single handle Delta faucet. The pressure recently dropped by about 50% in both the tub faucet and shower head. The rest of the house still works perfectly, including the sink that's right next to this tub. Any idea what could be causing this?
Time to rebuild or replace it.
If you were to contact the company with a pictue most often they will send you all the parts for free, worth a try. |
Any other thoughts on specifically what I can do to fix this without ripping out the tiles or drywall on the other side of the wall? I have no experience with this, but don't want to hire a plumber if it's something somewhat easy.
Let me know if anyone has any thoughts, thanks in advance! |
Deltas are easy to repair--the valve body is good for a life time---
Post a picture and some body will recognize it and tell you how to change the guts--- |
Lightfoots right.
May need to go buy a special tool to get the whole thing apart. It looks like a deep well hollow socket with a tee handle on it. |
Could it really be something as easy as a partially plugged valve cartridge?
michel zaki
:thumbsup:please clean the tap filter
if nothing changed u have to install larger pipe diameter 25 mm |
UPDATE
I took all of your advice and took the faucet apart. I went to Home Depot and found the correct catridge replacement. Before I reinstalled it, I turned the water back on and let the water pour out to clean the valves. The water came out so fast it almost knocked me over, so we're getting good pressure. I put everything back together and the pressure is still low! Any other thoughts, this is driving me nuts :censored: |
Is the shower head plugged up?
Remove the shower head from the shower arm and test it |
The shower head and tub faucet were both reduced about 50% at the same time, so I don't think it's the head.
| All times are GMT -4. The time now is 07:53 AM. |
