Water Pressure And Compressions - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-11-2007, 10:09 PM   #1
water pressure and compressions
I recently had a leaking compression stop that I tightened up and it seems to have stopped. Just for the hell of it I checked all the other compression stops and two more were leaking. One had a fast drip. I know they just started. Now I may be reaching here but could a spike in the water pressure cause compressions to suddenly start leaking?? What about draining the water pipes and then turning the water back on too quickly??
farrington135 is offline   Reply With Quote
Old 04-11-2007, 10:40 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
It is possible. A sudden spike in water pressure with the presense of water hammer. I would think it would need the water hammer invoked.
Just an increase should not cause it.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 04-12-2007, 12:23 PM   #3
thanks. I was wondering because a water heater pipe was replaced 2 weeks ago and when the water was turned back on and the faucets were opened there was quite a bit of banging when the air was forced out the the lines. This is when the valves started to drip.
