Water Pressure Booster Pumps - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-07-2007, 09:35 PM   #1
water pressure booster pumps
I had an Amtrol water pressure booster pump installed in 2003. Recently the "gland" fitting which makes the connection between the motor and the tank rusted out. After trying to get a replacement part from Amtrol I am told the pump is obsolete, has been redesigned with a different type fitting and the fitting I need is no longer available. Other than this problem this unit is in impecable condition. Is there anyone else that has experienced such problems? If so please advise me,,,,,,,,,THANKS
ksmith is offline   Reply With Quote
Old 07-07-2007, 11:54 PM   #2
Deplorable Electrician
MechanicalDVR's Avatar
Rewards Points: 81
Have you tried Grainger parts? They may have the part you need in a warehouse someplace. I would try Amtrol stocking distributers as well, just because a part is no longer made doesn't mean they aren't on a shelf somewhere.
MechanicalDVR is offline   Reply With Quote
Water pressure? What water pressure? mnp13 Plumbing 9 05-03-2007 03:32 PM
water pressure problem rgmetro Plumbing 6 04-09-2007 04:57 PM
High pressure in water line atlfiveo Plumbing 5 02-06-2007 10:04 PM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
New Help With Improving Water Pressure hayhursm Plumbing 1 01-31-2006 07:55 PM
