Water Pressure In Bathroom Very Low Every Else Good Since Please Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-31-2012, 12:20 PM   #1
Angry
water pressure in bathroom very low every else good since please help
i replaced my water heater that went bad with a reliance 30 gallon, since then i have no hot water pressure in the bath room but in kitchen and laundry room i have very good pressure what happened???????????????
jad555 is offline   Reply With Quote
Old 12-31-2012, 12:28 PM   #2
Plumber
Is it to all the fixtures in the bathroom ?
DidIDoThat is offline   Reply With Quote
Old 12-31-2012, 12:38 PM   #3
Rewards Points: 12,868
Happens all the time if you did not remove the aeriators on the sink and shower head to clean out the lines.
Old 12-31-2012, 02:04 PM   #4
Plumber & Gasfitter
Rewards Points: 77
If the pressure is still fine on the cold side then the clog will be before the aeriator. Most likely at the shut-off or at the cartridge.
joeplumber85 is offline   Reply With Quote
Old 12-31-2012, 06:34 PM   #5
Master Plumber
Javiles's Avatar
Rewards Points: 984
Looks like another hit and run post?
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 12-31-2012, 09:44 PM   #6
yes bath tub and the sink i have al most no hot water pressure thanks
Well Water Pressure Fluctuation cforbes Plumbing 13 10-01-2012 07:52 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Low hot water pressure in bathroom. Craive Plumbing 3 03-23-2010 07:58 PM
Lack of hot water pressure in bathroom sink kc1983 Plumbing 4 05-22-2009 10:24 AM
Water pressure dropping tucsoncop Plumbing 2 04-25-2009 01:19 PM
