Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-27-2010, 03:28 AM   #1
water pressure
Why Has My Hot Water Pressure Dropped
jubblies18 is offline   Reply With Quote
Old 12-27-2010, 09:46 AM   #2
Hot water pressure is controlled by the incoming cold water to the water heater. If it is only hot water that is low pressure, you may have a blockage in the hot water piping. Could also be a partially frozen pipe, but if so, it should quickly thaw with even a small amount of flow.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 12-27-2010, 10:29 AM   #3
BIGRED
Rewards Points: 252
Is your water heater old as in 8-12 years old?? It may be "calcifying" towards the bottom of the tank where the Hot water dip tube opening is inside the tank. Softened water will greatly extend the life of a water heater, but calcification eventually gets them all unless they spring leaks or have other problems.
Grampa Bud is offline   Reply With Quote
hot water pressure much lower than cold water pressure lockingpin Plumbing 5 12-26-2009 04:23 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 10:24 AM
Low water pressure upstairs but gauge reads 100psi? rivers72 Plumbing 7 11-15-2008 07:55 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 11:19 AM
