Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-27-2010, 06:51 AM   #1
47_47's Avatar
Rewards Points: 50
Water pressure
Let me start by thanking all of the members. I have a tpr valve leaking on my conventional gas water heater. I replaced it and the new one still leaks. I've researched this topic here, measured the pressure and found it will spike to 120 psi intermittently.
Older home, copper plumbing, has a pressure regulator installed and no expansion tank. Don't know the age, but we've lived here 10 years. I've just recently installed new bath tub (pressure balancing type, single handle Kohler), sink faucets and a new toilet.
My question is can one of the new fixtures be defective, allowing the spikes or do I have a failing pressure regulator? Are there other tests that I can do or just change the regulator? Any recommendations for replacement make/model in a 3/4" copper line and the optimum operating pressure?
Thank you,
Mike
47_47 is offline   Reply With Quote
Old 09-27-2010, 07:01 AM   #2
Rewards Points: 1,494
You need an expansion tank.
Water expands slightly when heated and this will force some out the temp/pressure relief valve on the water heater unless there was a dripping faucet somewhere.
The Following User Says Thank You to AllanJ For This Useful Post:
47_47 (09-27-2010)
Old 09-27-2010, 07:13 AM   #3
47_47's Avatar
Rewards Points: 50
Thanks for the fast response AllanJ. I know that water expands with an increase in temperature, but I haven't had any issues with my current set-up in the past 10 years. This is what has me puzzled. I forgot to mention that when initially turning on just a cold tap, I get a blast of water then it returns to normal.
Old 09-27-2010, 08:26 AM   #4
Rewards Points: 152
My vote is PRV.
It might have a tiny stone stuck between in the rubber or the seat allowing a slow build up, topping out at street pressure. When you turn on the tap, you release that high pressure and the PRV works again until it sits idle and allows the pressure to build up again.
burnt03 is offline   Reply With Quote
The Following User Says Thank You to burnt03 For This Useful Post:
47_47 (09-27-2010)
Old 09-27-2010, 08:52 AM   #5
Owner
LateralConcepts's Avatar
Replace the PRV. Use a Watts (brand) Regulator. Pressure should not exceed 80psi. 75 is ideal.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
The Following User Says Thank You to LateralConcepts For This Useful Post:
47_47 (09-27-2010)
Old 09-27-2010, 09:13 AM   #6
47_47's Avatar
Rewards Points: 50
Thanks to all who answered. I was leaning toward the prv.
Would the Watts N250 be suitable?
https://www.watts.com/pages/_product...s.asp?pid=3432
Mike
Old 09-27-2010, 11:49 AM   #7
Just call me Andrew
Rewards Points: 1,020
I think that one would work OK. I think that's the one I installed for my parents' lawn sprinkler system and it worked fine.
Andrew
secutanudu is offline   Reply With Quote
Old 09-27-2010, 01:34 PM   #8
Rewards Points: 152
This one might be better (https://www.watts.com/pages/_product...ls.asp?pid=776)
The nut on the underside (inlet side) can be removed to clean the screen.
Old 10-04-2010, 06:33 AM   #9
47_47's Avatar
Rewards Points: 50
Just a follow up, AllanJ was correct, I needed an expansion tank.
hot water pressure much lower than cold water pressure lockingpin Plumbing 5 12-26-2009 04:23 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 10:24 AM
Low water pressure upstairs but gauge reads 100psi? rivers72 Plumbing 7 11-15-2008 07:55 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 11:19 AM
