Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-15-2010, 11:08 AM   #1
Angry
water pressure
My washing machine has no water pressure, I try and turn the cold water line up and it shuts down and only hot water comes out. It takes all day to do 1 load of laundry. Help!
pickles is offline   Reply With Quote
Old 09-15-2010, 12:34 PM   #2
A little more information would be helpful. What type of hoses do you have connected to your washing machine? Could be that they are restricting your flow. Try disconnecting the hose from the washing machine and put the end in a bucket (or slop sink if available) and turn the water on - do you have normal pressure now? Is it possible there is some crud blocking the inlet of the washing machine - oftentimes there are little screen filters that can be cleaned.
H8Mondays is offline   Reply With Quote
The Following User Says Thank You to H8Mondays For This Useful Post:
pickles (09-21-2010)
Old 09-15-2010, 08:05 PM   #3
HVAC / Plumbing
I think there is also a screen on the fill valve
kenmac is offline   Reply With Quote
The Following User Says Thank You to kenmac For This Useful Post:
Old 09-15-2010, 09:26 PM   #4
Check the supply line
It may be a Watts flood preventer
These have been known to shut down the cold water with some washers
The Following User Says Thank You to Scuba_Dave For This Useful Post:
Old 09-21-2010, 03:26 PM   #5
thats exactly what it was, a flood preventer hose, thanks so much!
hot water pressure much lower than cold water pressure lockingpin Plumbing 5 12-26-2009 04:23 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 10:24 AM
Low water pressure upstairs but gauge reads 100psi? rivers72 Plumbing 7 11-15-2008 07:55 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 11:19 AM
