Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-17-2009, 11:01 AM   #1
water pressure
I have water tank 40ft vertical drop with 1.25 inch supply pipe which should generate 17psi. What will the water pressure be if I reduce to 1/2 inch at end of supply line
panhter is offline   Reply With Quote
Old 08-17-2009, 06:07 PM   #2
Rewards Points: 1,666
I really have no science behind my answer but my guess is that the psi in a static system (no flow) would be the same value as the same amount of water is being held back in the tubing so the mass is the same at the same height. If you need an exact answer, someone here may know but i did find a website you might try:
http://www.physicsforums.com/showthread.php?t=325576
Either way, let us know the right answer when you get it please.
bob22 is online now   Reply With Quote
Questions about water pressure regulation.. MrSimmonsSr Plumbing 21 05-13-2017 07:08 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
Water pressure? What water pressure? mnp13 Plumbing 9 05-03-2007 02:32 PM
