Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-24-2009, 02:09 PM   #1
Exclamation
Water Pressure
I live in the city and my connection to water heater is less than 100 feet away however my water pressure in my kitchen sink is barely stronger than well water, and nearly slows to a drip when I fold the water purifier down to purify my water. I have looked into "boosters" but not sure where to install them. They seem to run around 80 bucks and higher. Can you help?
Thanks!
chrispoarch is offline   Reply With Quote
Old 05-24-2009, 03:26 PM   #2
If the kitchen sink is the only problem then you need to find out why. It could be a partially closed shutoff valve or clogged supply line.
hayewe farm is offline   Reply With Quote
Old 05-24-2009, 04:15 PM   #3
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Unscrew the aerator on the sink and see if that helps. Doesn't take much to clog those up.
wirenut1110 is offline   Reply With Quote
Questions about water pressure regulation.. MrSimmonsSr Plumbing 21 05-13-2017 07:08 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
Water pressure? What water pressure? mnp13 Plumbing 9 05-03-2007 02:32 PM
Bad water pressure (well water) fnkyniedls Plumbing 2 10-22-2006 11:42 PM
