Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-17-2012, 04:48 PM   #1
Water pressure
I just bought a house in the North Georgia mountains. The house was built in 2000, so it's not that old. It was however, a foreclosure and in need of MUCH repair. Pretty much everything was stripped from the house. We are on public water which is fed from a tank just up the mountain from me. My problem is that I do not have much for water pressure. Is there a way to increase pressure to the house being on a public system?
Savinmoney is offline   Reply With Quote
Old 10-17-2012, 05:26 PM   #2
Rewards Points: 12,856
And how much pressure is not much pressure. Have you put a gauge on it to see?
Is the "pressure" low everywhere or just one faucet or shower?
What size lines where run as the main lines?
Savinmoney (10-17-2012)
Old 10-17-2012, 05:31 PM   #3
Rewards Points: 438
If you google water booster pump or increase water pressure etc. you'll find numerous kinds of pumps that claim they'll solve your problem. I've never needed one so I have no first hand experience with any of them.
But since you are Savinmoney you might consider checking on what pressure you should have at your location before investing in something that may or may not be needed. With plumbing anything is possible and it could be a simple solution.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Old 10-17-2012, 05:44 PM   #4
Joecaption..I have not put a gauge on it. Looks like main pipe from road is about 1-2 in. but would have to look at it again to be sure. Other lines are 1/4-1/2. Not at the house right now to double check these sizes. Pressure is weak in the whole house, especially if more than one faucet is on.
Old 10-17-2012, 05:53 PM   #5
Main line should be a min. of 3/4, 1" is better, all main runs in the house needed to be at least 3/4" then 1/2 to the supplys.
What you think is low pressure is really low flow.
When all the faucets are shut off the pressure will be equal anyplace you check it, once the faucets opened up if the lines to small the pressure drops and flow is reduced.
Picture a garden hose with a gauge where it connect at the house and turn it on. The pressure drops, now stand on the hose, pressure goes up on the gauge but flow goes down.
Old 10-17-2012, 06:00 PM   #6
Joe..Thanks for the visual! makes since to me!
Old 10-17-2012, 06:26 PM   #7
GBrackins's Avatar
Rewards Points: 2,108
silly question? have you check all of the valves to make sure one of them is not partially closed? this would certainly reduce flow. if the place was foreclosed then at some time I'm sure the public utility shut off the water, maybe it did not get turned on fully.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
Old 10-17-2012, 06:36 PM   #8
Gary, Not so silly of a question, but yes, all valves are wide open. Thanks
Old 10-17-2012, 07:12 PM   #9
raylo32's Avatar
Rewards Points: 1,226
Is there a pressure regulator in your system to reduce the supplied municipal pressure down to what you need in the house? If so, maybe alls you need is to adjust this. But as mentioned before you really need to put a gage on it and see what you have in the first place.
Live long and prosper.
raylo32 is offline   Reply With Quote
The Following User Says Thank You to raylo32 For This Useful Post:
Savinmoney (10-18-2012)
Check valve gimaarob Plumbing 13 10-27-2011 11:13 PM
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 08:24 PM
hot water pressure much lower than cold water pressure lockingpin Plumbing 5 12-26-2009 05:23 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
