Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-01-2012, 12:18 PM   #1
water pressure
Hi there if i am wanting to run a water line to the roof on a flat top commerial building and have a 1/2 " type line to work with am i doing a fair job with water pressure to stay with that size line? I am giong to try to run a sprinkler system to cool the roof down. I do have a big area to cover and am going to need atleast two garden sprinklers up there. Question is should i step up line size to help keep pressure and/or am i giong to lose pressure any how just because I'm going 24' above ground and need something different.
hommie2 is offline   Reply With Quote
Old 07-01-2012, 12:44 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 444
Why don't you hang a garden hose over the side and do a test run? Hook it to a hose bib and see if it's satisfactory?
Old 07-01-2012, 12:53 PM   #3
jburd964's Avatar
Rewards Points: 166
You lose one pound of pressure for every thirty inches of rise in elevation. Attempt to use two sprinklers if flow is enough step up line size.
I'm not a professional., But I did stay at Holiday Inn Express last night.
Gun control isn't about guns, IT'S ABOUT CONTROL.
jburd964 is offline   Reply With Quote
Old 07-01-2012, 01:20 PM   #4
biggles's Avatar
consider just filling the roof with water 6"-12" deep then just let the sun evaoprate the water that will temper the building as the water evaps what state you in?
Check valve gimaarob Plumbing 13 10-27-2011 11:13 PM
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 08:24 PM
hot water pressure much lower than cold water pressure lockingpin Plumbing 5 12-26-2009 05:23 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
