-   -   water pressure (http://www.diychatroom.com/f7/water-pressure-148795/)
hommie2 07-01-2012 12:18 PM
water pressure
Hi there if i am wanting to run a water line to the roof on a flat top commerial building and have a 1/2 " type line to work with am i doing a fair job with water pressure to stay with that size line? I am giong to try to run a sprinkler system to cool the roof down. I do have a big area to cover and am going to need atleast two garden sprinklers up there. Question is should i step up line size to help keep pressure and/or am i giong to lose pressure any how just because I'm going 24' above ground and need something different.
TheEplumber 07-01-2012 12:44 PM
199 Attachment(s)
Why don't you hang a garden hose over the side and do a test run? Hook it to a hose bib and see if it's satisfactory?
jburd964 07-01-2012 12:53 PM
You lose one pound of pressure for every thirty inches of rise in elevation. Attempt to use two sprinklers if flow is enough step up line size.
I'm not a professional., But I did stay at Holiday Inn Express last night.
biggles 07-01-2012 01:20 PM
consider just filling the roof with water 6"-12" deep then just let the sun evaoprate the water that will temper the building as the water evaps what state you in?
