Old 11-20-2008, 09:05 PM   #1
Water Powered Sump Pump
We're looking to get our sump pump replaced, and the guy said that we shouldn't get a battery-powered backup, as that goes out after a few hours. Instead, he said that we should use a water-powered sump pump, which runs on water, and not on any power, so it can run infinitely, even with a prolonged power outage.
Has anyone ever heard of this? Is it worth it to pay more to get this kind of sump pump?
Thanks in advance
acuteot is offline   Reply With Quote
Old 11-21-2008, 10:36 PM   #2
Not until I ran a google search on "water powered sump pump".
Reilley is offline   Reply With Quote
Old 11-21-2008, 11:09 PM   #3
Yes. They are quite common. They are expensive, but if you have a sump that fills quickly and are in an area with frequent power outages I think it would be a good investment.
http://www.popularmechanics.com/how_...c/1275381.html
http://www.libertypumps.com/product_...nCat=11&SubCat=
http://www.pbs.org/thisoldhouse/vide....php?item=sump
jerryh3 is offline   Reply With Quote
Old 11-22-2008, 10:53 AM   #4
This depends on how often and for how long your power typically goes out. Also how quickly your sump fills up. Water powered pumps are a good thing for emergencies but the amount of water needed to operate them is large. Last one I saw took two gallons of water to pump one gallon from the sump. You also need somewhere for all this water to go. Myself, I would go for a generator which could be used for other things when not needed for the sump. Just my opinion.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 11-23-2008, 07:00 AM   #5
JDC
Plumbing Contractor
JDC's Avatar
Yep I've installed a few water powered backups. I've also had a few problems with the sch 80 nipples and fittings that come with them. If you get one just be sure things aren't OVERtightened. Those nipples and/or fittings will crack and then you wind up paying for a new laminate floor
JDC is offline   Reply With Quote
Old 11-23-2008, 07:31 AM   #6
had i known about these, we would never have sold/installed battery backup pumps,,, just wondering if its plumber's work ( soldering/copper lines ) or anyone's.
yes.itsconcrete is offline   Reply With Quote
Old 11-23-2008, 10:39 PM   #7
Thanks, good info there!
Old 11-23-2008, 10:40 PM   #8
We haven't moved in yet, but this house has had a history of flooding, as have many houses in the neighborhood. But I will ask my plumbing guy about this.
Tags
sump pump, water powered
Sump pump pit water level --- problem de12 Plumbing 49 02-27-2011 02:42 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
Sump pump pit water level Ralph123 Building & Construction 6 07-24-2008 06:33 AM
Water Mystery - Sump Pump Set Right? robertr4836 General Discussion 4 02-13-2008 03:32 PM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 12:59 PM
