#1 |
Just call me Andrew
Water-powered sump pump
I have a friend who's basement flooded due to a power failure during a storm. I've head of "water-powered" sump pumps that use municipal water (and wastes lots of it) in a venturi system to siphon water out of the pit.
Do these work well? If so, any recommendations on which to buy?
Andrew |
#2 |
Below Grader
A water powered sump pump is usually used as a backup pump, because it can run when the power goes out. It indeed works with municipal water and relies heavily on the water pressure in your house.
It doesn't work in areas where municipal water has low pressure or in homes with well water. Water pumps require 3-5 gallons of town water to be pumped away for each gallon of water you pump out of your basement, which is why they are considered wasteful. A good alternative to them are battery operated backup sump pumps. Good models come with batteries specifically developed for this application (which, unlike generic marine or car batteries, will not die if they remain unused for long periods of time). These batteries can pump up to 12,000 gallons on a full charge and good backup pumps can be hooked to multiple batteries for longer lasting protection. |
#3 |
Just call me Andrew
Oh, I had only intended to recommend it as a backup for when the power goes out. We live on city water, 70-80psi, so no issue there.
Is there one of this type (water-powered) that works better than another? Recommendations on a good battery-backup for a sump?
Andrew |
#4 |
I have also been investigating water powered sump pumps as a backup. Some of the makes I have been investigating are Basepump, Zoeller, Wayne, and Liberty. These pumps typically need at least 40 lbs of water pressure in order to work, and higher water pressure makes them more efficient. The figures I have typically seen indicate that 1 gallon of water into the pump will remove about 2 gallons of water from the sump. In looking at ratings on various forums the Basepump models seem to do well, and there are mixed reviews on the other makes. I haven't made a choice yet for which make to go with, but I thought this information would help. There are a few videos on YouTube showing water powered sump pumps, and they are somewhat helpful but I haven't found a really good source for reviews yet.
#5 |
Just call me Andrew
I looked into a bunch of these this weekend, it seems like Basepump gets the best reviews. They are also pricey, especially considering you'd need to buy other things as well, like a check valve for the water system. I do like the idea that it will always work. The battery units concern me since they sit unused for possibly months on end, who knows if the battery will even hold a charge when the time comes.
Any other thoughts on these?
Andrew |
#6 | |
Experienced
Water-powered sump pumpQuote:
I would test this system at least twice a year (as should be done with any backup system) and it performed each and every time. As a safegaurd I did purchase a second battery and connected it to the system in parrallel thus therocially doubling its operational time. Mark
When its all said and done there is usually more said than done To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#7 |
best is the gaurdian...it's been on HGTV, this old house, ect..but it's pricey..400
I also am looking for 1. our local store stopped selling zoeller. they kept coming back???. I think i'm going to try the liberty. I live on the water in Baltimore, md and have a basement that is finished. i get power outages alot..my sump pump also works every hr. I'd be interested to hear from people who have them.... |
| Display Modes | |
| Sump pump jerks when it turns on | Sparkastic | Plumbing | 3 | 08-25-2011 07:51 PM |
| Sump pump used to be dry, now dark nasty water in it | helencpdmd | Plumbing | 2 | 08-18-2010 07:17 AM |
| Yet another sump pump / pit question | SeanFlynn | Plumbing | 0 | 01-24-2010 02:07 PM |
| Sump pump issues | GeorgeHuhges | Plumbing | 3 | 10-19-2009 03:43 PM |
| Water Mystery - Sump Pump Set Right? | robertr4836 | General Discussion | 4 | 02-13-2008 03:32 PM |
