-   -   water pooling ontop of water heater (http://www.diychatroom.com/f7/water-pooling-ontop-water-heater-27248/)
nannerkrns 09-23-2008 01:05 PM
I have a relieance sta-kleen electic water that is 6 years old. I noticed I have water pooling ontop of the heater around the water inlet. If I turn the water off, dry the water it stays dry. When I turn the water back on and use the hot water the pooling starts again. Is it time to replace the water heater or is there a fix?
Termite 09-23-2008 02:08 PM
I don't think it is the tank. It sounds to me like you've got a plumbing leak at the connection to the tank or slightly above it.
Can you post a picture of where the water is pooling, and the plumbing above?
SD515 09-23-2008 11:04 PM
Define 'turn the water off'. The cold water shut off valve at the wtr htr?
Initially it does sound like a leak between the valve and the tank. A photo would be nice.
