Old 07-30-2012, 11:59 AM   #1
Water pipes making noise when shutting off
Whenever I shut off my water at my sinks or showers, it makes a whining noise until the water is completely shut off. How can I fix this?
Jughead99 is offline   Reply With Quote
Old 07-30-2012, 12:47 PM   #2
A few things to check are the water pressure, it should not be any higher then 60 PSI, and if it's old style single hand faucets it can be a loose or worn washer.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Main water valve in condo shut off, but neighbors can still hear water running through pipes. cookiebird87 Plumbing 1 12-01-2010 05:43 PM
Hot water pipes (closed system) vibrate very loudly. Peety HVAC 8 02-07-2010 10:53 AM
Squealing noise when water pipes shut off wrencho Plumbing 2 05-12-2008 11:01 PM
