Water Pipes Are Making A Moaning Noise. - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-28-2012, 06:15 AM   #1
Water Pipes are making a moaning noise.
We had cold water valve replaced behind the water heater. Now when we turn on the water or flush the toliet anywhere in the house it makes a moaning noise. What is wrong?
linda white is offline   Reply With Quote
Old 08-28-2012, 10:36 AM   #2
Rewards Points: 1,596
See if the valve is open all the way.
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
linda white (09-03-2012)
Old 08-28-2012, 10:43 AM   #3
Rewards Points: 13,748
May also have air trapped in the lines.
Open all the faucets one at a time starting with the ones closest to the heater, make sure to open the outside faucets, flush the toilets and run the shower.
Only need to run each one for about 1 min.
Worth a try and it's free.
Old 08-28-2012, 11:06 AM   #4
A hammer arrestor might solve the problem.
Fishinbo is offline   Reply With Quote
Old 08-28-2012, 11:12 AM   #5
DIY Enthusiast
Is the moaning noise coming from the valve? If so then I would suspect that it's not fully open or something has gotten caught maybe?
I like the idea of trying to purge any possible air first though to see if it fixes it. If the moaning comes from the faucet, maybe some seals need to be replaced or valves cleared up.
Good luck!
ajmckay is offline   Reply With Quote
The Following User Says Thank You to ajmckay For This Useful Post:
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Main water valve in condo shut off, but neighbors can still hear water running through pipes. cookiebird87 Plumbing 1 12-01-2010 04:43 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Hot water pipes (closed system) vibrate very loudly. Peety HVAC 8 02-07-2010 09:53 AM
Squealing noise when water pipes shut off wrencho Plumbing 2 05-12-2008 10:01 PM
