Water Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-29-2009, 07:57 PM   #1
Water Pipes
Something weird is happening! The hot and cold water is fine in one of the bathrooms, the other bathroom only the cold water works, and in the kitchen neither of them work??? What could be the problem????? Any help????
bossmanbuzz is offline   Reply With Quote
Old 12-29-2009, 08:08 PM   #2
firehawkmph's Avatar
Rewards Points: 1,902
Bozzman,
Take a second to update your profile so we can help with your questions. It would be nice to know aprox. where you are located so we have an idea what the temperature is in your area. Could use more info also. Was everything working fine the day before and today it didn't, etc.? Possible frozen pipe?
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 12-29-2009, 08:16 PM   #3
That is what i was thinking but i am not actuallly there. My parents are at their trailer in Gettysburg and it worked last time they were there fine. I already had them check if the faucets were clogged and they were not. Is it possible for some of the faucets in the place to work and not other ones??
Old 12-29-2009, 08:35 PM   #4
How cold has it been and has the place been heated all the time? It certainly could "catch" a pipe (freeze one) if the weather has been cold enough or if a line is exposed to a cold enough draft somewhere under the trailer
Is this place lived in all the time? Is it a travel trailer or a trailer/mobile/modular home?
meboatermike is offline   Reply With Quote
Old 12-29-2009, 08:42 PM   #5
It has been in the 40's mainly during the day except for recently, in the 20's. The modular home is not lived in at all times, just every weekend or every other but when not in use the lines get drained at least that is what they told me. I think they might have got frozen but i wanted to see if it could have been something different.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Frozen Hot Water Pipes TravisW Plumbing 11 12-10-2009 05:26 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 03:01 PM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 10:29 AM
