Old 11-28-2012, 04:32 PM   #16
Special User
Water pipe sizing
Originally Posted by spring3100 View Post
my Hot Water branch circuits are 1) 1/2 to the kitchen
As long as that pipe supplies nothing else besides the kitchen sink and dishwasher, you are fine to tie that existing 1/2 into your new upgraded mainline.
2) 1/2 to the two upstairs bathrooms
This needs to be upgraded all the way up.
3) 1/2 to first floor lavette and
What's a lavette, is that like a powder room or half bath (no shower or tub)? A powder room only has one lav sink that requires hot water, so you could tie the existing 1/2 into your new upgraded mainline.
4) 1/2 to washing machine,
As long as that pipe supplies nothing but the washing machine, you are fine to tie the existing 1/2 into your new upgraded mainline.
tylernt is offline   Reply With Quote
Old 11-29-2012, 08:50 AM   #17
Water pipe sizing
Me thinks I will upgrade the existing 3/4 coming off the meter to 1 inch,then change all the 1/2 water supply to the Hot Water Heater and 1/2 hot water distribution line to 3/4.
This will give me more than enough pressure and flow for my system,based solely on my own knowledge of this house.
As to why the plumbing code doesn't address this exact sizing situation?????
spring3100 is offline   Reply With Quote
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 06:55 AM
Pipe Sizing for Hot Water Heating System tmguinan HVAC 7 09-23-2012 08:59 PM
Water Pipe Calcs - Interesting Result ddawg16 Plumbing 0 05-30-2012 12:19 PM
Do I need a ground rod to replace copper water pipe mfkcbk Electrical 10 11-11-2010 05:03 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
