Old 11-26-2012, 08:40 PM   #1
Water pipe sizing
I have a 1 inch water meter,which supplies a 3/4 inch cold and a 1/2 inch hot water lines.
House currently has 2 full baths,1 Lavette,Kitchen sink with Dishwasher,Washing Machine,2 hose bibs and inground sprinklers.
Looking to add a 3/4 bathroom in my basement.
Have 50 psi pressure at the meter.
House is two stories with a basement.
House was built in 2000.
Will I have enough pressure and flow for the new bathroom,or will I need a piping upgrade.
spring3100 is offline   Reply With Quote
Old 11-26-2012, 09:10 PM   #2
Water pipe sizing
All the main runs needed to be at least 3/4" both hot and cold not just the cold line.
It's not pressure that's going to be the issue it's flow.
Old 11-26-2012, 09:19 PM   #3
Water pipe sizing
It all depends on the plumbing code in your state. Here in MA, you should already have 3/4" cold and hot water mains, and a 1" water service. With the addition of the new 3/4 bath, the cold water main would have to be bumped-up to 1", and the water service would have to be 1 1/4".
Ishmael is offline   Reply With Quote
Old 11-26-2012, 09:27 PM   #4
call me E
TheEplumber's Avatar
Water pipe sizing
I'm too lazy to dig out my code book for sizing charts but you will be undersized on both hot and cold. You might squeak by with the service though
Old 11-26-2012, 09:31 PM   #5
Water pipe sizing
One of the cases where bigger is really better.
Old 11-28-2012, 10:10 AM   #6
Water pipe sizing
Need to do a new HW Heater anyway,if I repipe and make the HW line 3/4 from the cold water supply thru heater to the new basement HW takeoff and leave everything else 1/2 inch do you think it will pass muster?
Have not had any problems to date with volume or pressure throughout the house in the 12 years I've been there.
Old 11-28-2012, 10:36 AM   #7
JOATMON
ddawg16's Avatar
Water pipe sizing
I'm not the expert here....but I have made some of those mistakes....the 1/2" is too small for you hot water...
You basically want the 3/4" to act as a main supply to each area....once you get to a bathroom tee off with a 1/2" line.
You might be ok now...but wait until you get the other bathroom going and someone flushes a tolet....
As I have mine now...you can be in the shower and flush the tolet next to it and not even know except for the sound.
One last thing.....make sure you debur the inside of those copper pipes as you run the lines. It does wonders for cutting down the noise.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 11-28-2012, 12:28 PM   #8
Special User
Water pipe sizing
The answer can be found in calculating the Water Supply Fixture Units or WSFU for your house. There are code tables to show you what size of pipe is required to supply the fixtures installed in your house. As I recall, the length of the pipe runs come into the calculation too.
For example, in my case (2 bath, 1 kitchen, 1 laundry, 2 hosebibs, 75' pipe run), the tables required 1" cold and 3/4" hot mainlines.
tylernt is offline   Reply With Quote
Old 11-28-2012, 12:34 PM   #9
JOATMON
ddawg16's Avatar
Water pipe sizing
Boy....looks like I'll be in trouble......
I have a 3/4" line coming in ......3 full baths....laundry.....kitchen....
My
and
Old 11-28-2012, 12:37 PM   #10
Special User
Water pipe sizing
No doubt installed to code at the time the house was built, so you're good. On the other hand, I gutted and replumbed 99% of the pipes, so I wasn't grandfathered in.
I'm not sure how grandfathering applies when only upgrading part of a plumbing system though.
Old 11-28-2012, 12:39 PM   #11
JOATMON
ddawg16's Avatar
Water pipe sizing
Not exactly....I'm in the middle of a 2-story addition right now...I added 2 bathrooms.....laundry got moved from the kitchen to the addition....
My
and
Old 11-28-2012, 12:41 PM   #12
Special User
Water pipe sizing
Well... hopefully the inspector passes it then. Maybe offer a 12-pack to take home with him?
Old 11-28-2012, 12:45 PM   #13
JOATMON
ddawg16's Avatar
Water pipe sizing
I bribe him with a Pepsi every time he shows up...we actually joke about it......
There is nothing on my prints regarding it....so the chances are they won't make an issue of it....
My
and
Old 11-28-2012, 12:53 PM   #14
call me E
Water pipe sizing
There's actually 2 major steps to sizing water. First is the service- you need to know the lowest minimum pressure supplied(it does vary). Elevation from the source to the highest outlet. Length of service line and the water fixture units calcs. for the house. Once you have this info you can refer to the sizing charts in your local code book.
Now you know the service size, then you need to calc the CW and HW lines seperatly inside the home based on each fixtures water fixture units. There are some general rule of thumbs that plumbers follow such as 2 fixtures on a 1/2" line. But I've been bit by that rule also- such as soaker tubs and elaborate showers
Old 11-28-2012, 03:41 PM   #15
Water pipe sizing
I'm looking at the residential code trying to figure out my WSFU's for a 1 inch meter with a 3/4 inch distribution pipe and alas,that combination doesn't exist in the code.
Are I an idiot (a distinct possibility),or did a druken plumber build my house?
Either way,since my Hot Water branch circuits are 1) 1/2 to the kitchen 2) 1/2 to the two upstairs bathrooms 3) 1/2 to first floor lavette and 4) 1/2 to washing machine,that if I upgrade my distibution pipe from 1/2 to 3/4 I should be OK both pressure and flowwise,and in the eyes of the plumbing law,are I coorect in this assumption?
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 06:55 AM
Pipe Sizing for Hot Water Heating System tmguinan HVAC 7 09-23-2012 08:59 PM
Water Pipe Calcs - Interesting Result ddawg16 Plumbing 0 05-30-2012 12:19 PM
Do I need a ground rod to replace copper water pipe mfkcbk Electrical 10 11-11-2010 05:03 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
