Water Pipe Noises - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-03-2008, 10:39 PM   #1
Water pipe noises
After I run any water in my house or flush any of the three toilets my water pipes make a wailing noise. Any suggestions? Is this a easy fix or do I need to call a plumber? Also I can not tell where it is coming from I have search for hours!! Any help will do.. Thanks in advance
redtruck4608 is offline   Reply With Quote
Old 01-04-2008, 05:31 AM   #2
first turn off the toilets and then check? toilets can make alot of noise when the age, or warter conditions.
then gheck the hose bibs. are they on? if there is a vacum breaker installed and the hose is on but not in use when the pressure in the line changes, it will make noise
ranman469 is offline   Reply With Quote
Old 01-04-2008, 08:09 AM   #3
Loose pipes can cause noise; saddle pipe clips will solve the problem of rattling pipes.
Jimbob is offline   Reply With Quote
Old 01-04-2008, 02:27 PM   #4
Long-Time DIYer
Mike Swearingen's Avatar
A "wailing noise" could be caused by a faulty toilet tank water inlet valve.
Check each, one at a a time, until you find the one causing the noise, and then replace it with a Fluidmaster 400A float-cup type valve.
They cost less than $10 bucks, and are very easy to install. Just follow the illustrated directions that come with them.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 01-04-2008, 10:51 PM   #5
Journeyman Plumber
Ron The Plumber's Avatar
If it's in all fixtures of the house no matter what is running, check for high water pressure, if too high, 80psi+ this will make them scream, you could need a pressure reducer valve installed or you have one that went bad and will need replaced.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Running hot water causes pipe rumbling mpinchinat Plumbing 13 12-25-2007 11:13 AM
Water pipe heater delema arichard21 Electrical 5 12-17-2007 07:56 PM
Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) markmaclean80 Plumbing 6 08-22-2007 08:20 PM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
Water pipe selection??? DK75 Plumbing 5 06-05-2006 11:09 PM
