Water Pipe Hangers - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-25-2013, 11:10 PM   #1
Rewards Points: 147
water pipe hangers
hi folks,
I'm wondering if using the copper hangers that look like pieces from a coat hanger is the best method to secure water pipes to a joist. The reason I ask is my pipes are very loud when turning the water on and off and I'd like to get them secured better to try and eliminate the noise and prevent any solder joints from leaking from the rattling around.
I snapped a photo of my setup:
thanks,
Andrew
andrewjs18 is offline   Reply With Quote
Old 12-25-2013, 11:35 PM   #2
Plumber & Gasfitter
Rewards Points: 77
water pipe hangers
Hangers are fine. Sounds like you are experiencing water hammer, and you should be looking into water hammer arrestors.
joeplumber85 is online now   Reply With Quote
Old 12-25-2013, 11:38 PM   #3
water pipe hangers
Those hangers have been used for years in the trade to secure copper lines and work well. Your banging pipes are likely a result of water hammer. Do you know if you have any water hammer arresters or air chambers installed in your system; Especially around fast closing solenoid valves such as your washing machine or dishwasher?
dannyoung85 is offline   Reply With Quote
Old 12-26-2013, 12:20 AM   #4
Rewards Points: 2,220
water pipe hangers
Not my choice for hanging. I always ran my water tight to the joist using wrap around plastic hangers.
Ghostmaker is online now   Reply With Quote
Old 12-26-2013, 11:23 AM   #5
Rewards Points: 147
water pipe hangers
I seriously doubt there are any water hammer arresters installed on my system. I had to look up what they even look like and I'm pretty confident in saying that I do not have any in my house whatsoever.
that aside, is it a bad idea to pick up some more of those copper hangers to help secure the pipe better? in spots, the line goes for a decent span without any hangers.
Old 12-26-2013, 11:31 AM   #6
water pipe hangers
First you need to find out what your house water pressure is. If over 80 LBS you will need a pressure reducing valve. Secondly a water hammer arrestor on your washer hook ups and it would also help to not have copper hanging loose in that type of hanger. I'm looking at your picture and that looks like rust on them hangers.
As a plumber I was taught that that hanger was for gas line only.
I would get this hanger they hold the pipe securely...
http://www.plumbingsupply.com/hangers.html
Old 12-26-2013, 11:50 AM   #7
Rewards Points: 147
water pipe hangers
that can be seen on the meter that's attached to the incoming water line, correct?
also, I noticed the water noise happens whenever the water is in use, whether it be for the washer, faucets, dishwasher, shower, toilets, etc., but I definitely notice it more often when the faucets are turned on/off since they're used more often.
when I get home from work tonight, I'll try to take a short video of what I hear in my basement when my wife turns the water on and then off.
Old 12-26-2013, 11:26 PM   #8
Rewards Points: 147
water pipe hangers
hi folks,
here's 2 short clips where I had my wife turn the faucet on and off in our kitchen:
http://andrewshemo.com/My%20Movie.mp4
http://andrewshemo.com/My%20Movie2.mp4
Old 12-27-2013, 09:02 AM   #9
Rewards Points: 147
water pipe hangers
Originally Posted by audrycampbell View Post
I think the first and most important thing is accurately be aware of the actual thickness of the wall you are hanging the pipe from and the other thing is spacing between size of your pipe and size of your pipe hangers. I think in your case the distance is large. This is the reason of the loudness in the pipe.
the pipe is hung from thicker floor joists.
that said, there does seem to be some longer spans without any hangers and then in the 2nd video I posted above, there's no hanger on that section of pipe at all.
Old 12-27-2013, 09:32 AM   #10
Plumber/Contractor
TheEplumber's Avatar
Rewards Points: 2,950
water pipe hangers
As mentioned- get a pressure gauge and confirm water pressure is below 80 psi. If above 80psi a pressure reducing valve should be installed
bridge between your joist and pipes with a wood blocking and install these pipe anchors (or similar) at max. 6ft spacing. http://www.homedepot.com/p/SharkBite...ipe%252Bclamp#
Old 12-27-2013, 09:54 AM   #11
PoleCat's Avatar
Rewards Points: 898
water pipe hangers
My pipes make some noise just from water flowing. I think it is cavitation in short 90s.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is online now   Reply With Quote
Old 12-27-2013, 10:07 AM   #12
JOATMON
ddawg16's Avatar
Rewards Points: 3,158
water pipe hangers
The most common cause of that noise is a lazy plumber not de-burring the inside of all the pipes.
My house 'used' to have a gate valve at the front as the main cut off. The pipe enters the house right by the kitchen sink. If 'any' water was flowing, you could always hear it. About 5 years ago I replaced the gate valve with a real ball valve. As I was taking everything apart I noticed a pretty good ridged on the inside created when you use a typical pipe cutter.
I de-burr my cuts....so once it was all put back together.....NO noise. Now, it's almost impossible to tell when any water it flowing.
Here is a pic of one of the fittings. Notice the crude inside? That was the gunk that packed up against the pipe fitting because of the big burr.
ddawg16 is online now   Reply With Quote
How to apply caulk to seal water pipe through basement wall goshenplumber General DIY Discussions 4 07-08-2013 09:40 PM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 12:33 PM
loud jackhammer-like noise from hot water pipe omar Plumbing 15 01-08-2012 02:53 PM
Basement drain pipe "pit" ground water fix. alecmcmahon General DIY Discussions 13 12-01-2010 06:42 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
