Water Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-14-2011, 02:58 PM   #1
water pipe
Hi my names jon,id like to know how to block a hot water pipe
jonnywatch is offline   Reply With Quote
Old 10-14-2011, 03:01 PM   #2
Lightfoot's Avatar
Rewards Points: 272
usually by putting a shutoff on the pipe or turning off the main.
(if by "block-you mean block the flow of hot water")
ya might wanna give a lil more info on what you're trying to do and what kind of pipe it is.
Lightfoot is offline   Reply With Quote
Old 10-15-2011, 12:30 AM   #3
Cut it and cap it. The type of pipe dictates how it can be terminated.
VIPlumber is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
loud jackhammer-like noise from hot water pipe omar Plumbing 15 01-08-2012 01:53 PM
Big water leak under house Puzzles Plumbing 4 04-27-2011 02:50 PM
Basement drain pipe "pit" ground water fix. alecmcmahon General DIY Discussions 13 12-01-2010 05:42 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
